[OpenLayers-Users] Right-click menu
Graham Davis
gdavis at refractions.net
Fri Feb 23 11:29:32 EST 2007
Sure,
The javascript event object contains information about buttons clicked.
The mouseDown function should already be doing a test to see if the
click is a left-click (and exits the function if it isn't). I added a
function to Events.js for checking right-clicks similar to the
left-click one:
isRightClick: function(event) {
return (((event.which) && (event.which == 2)) ||
((event.button) && (event.button == 2)));
Then in MouseDefaults.js I modified mouseDown like this:
mouseDown: function(evt) {
// on left click, do map dragging stuff
if (OpenLayers.Event.isLeftClick(evt)) {
... put usual map dragging code here
// on right-click show map menu
else if (OpenLayers.Event.isRightClick(evt)) {
... do your right-click code here
Graham.
Robert Buzink wrote:
> that's great. I want that :-). Could you tell me how you managed to
> 'properly
> recongnize a right-click event in the MouseDefeaults.js file on
> mousedown'?
> On 2/21/07, *Graham Davis* <gdavis at refractions.net
> <mailto:gdavis at refractions.net>> wrote:
> Well, I seem to have found the answer to my own question, so I thought
> I'd email it to the list just in case anyone else needs to know how.
> Basically there is an oncontextmenu event for DOM objects. You can
> assign this to a function and put any code you like in there, and then
> return false at the end to ensure the event stops and doesn't display
> the browser's context menu. So I added this to my map object to
> disable
> all browser context menus from appearing on the map like so:
> map.div.oncontextmenu = function noContextMenu(e) {return false;};
> Seems to work well in both IE and FF (haven't test Opera or on a Mac).
> Graham Davis
> Refractions Research Inc.
> gdavis at refractions.net <mailto:gdavis at refractions.net>
> Graham Davis wrote:
> >I'm trying to implement a right-click menu on my map, similar to what
> >you see here: http://maps.ask.com/maps. I've been able to properly
> mousedown.
> >My problem is that the browser's own right-click menu also
> appears, and
> >I need to disable or stop this. I've tried stopping the event from
> >propagating in the mousedown function after my code (and in the
> mouseup
> >function since that is when the browser menu seems to appear) however
> >this doesn't stop the browser menu from appearing.
> >Has anyone been able to implement a right-click menu on their map
> that
> >properly disables the browser's right-click menu?
> >Also, this might be of importance, but I'm using the vector branch of
> >code. I've noticed that when not using a vector layer, the
> right-click
> >menu on the map brings up the image menu as you have clicked on
> an image
> >in the map. When there is a vector layer overtop, right-clicking
> brings
> >up the standard browser menu where you can view source and
> whatnot, so
> >the menus are different. However, I think any fix for this would
> work
> >for both (and I have been testing everything I try both with and
> without
> >a vector layer). So far nothing works.
> Users mailing list
> Users at openlayers.org <mailto:Users at openlayers.org>
> http://openlayers.org/mailman/listinfo/users
> <http://openlayers.org/mailman/listinfo/users>
> Robert Buzink, website ontwerp en ontwikkeling
> Sint-Pietersaalststraat 123
> 9000 Gent
> +32 (0)9 33 00 267
> +32 (0)487 548 414
> post at robertbuzink.nl <mailto:post at robertbuzink.nl>
> robertbuzink.nl/webdesign <http://robertbuzink.nl/webdesign>
Graham Davis
