[OpenLayers-Users] Right-click menu
Graham Davis gdavis at refractions.net
Fri Feb 23 19:12:40 EST 2007
While you can figure out what mouse button was pressed that way, I
couldn't figure out how to prevent the browser's contextmenu from
appearing without adding the function for the oncontextmenu event.  The
browser's context menu seems to fire and appear before the OpenLayers
mousedown function is called, so I couldn't just stop the event....
unless I missed something during my tests.  Have you been able to
successfully stop the browser's right-click menu from appearing that way?
Graham Davis
Refractions Research Inc.
Lance Dyas wrote:
>The mousedown event has a property which tells which button is
>pressed... which
>is the "correct" way to do it instead of the "oncontextmenu" but
>oncontextmenu might
>be so broadly supported that nobody cares about Opera ;-)
>Robert Buzink wrote:
>>that's great. I want that :-). Could you tell me how you managed to
>>'properly
>>recongnize a right-click event in the MouseDefeaults.js file on
>>mousedown'?
>>On 2/21/07, *Graham Davis* <gdavis at refractions.net
>><mailto:gdavis at refractions.net>> wrote:
>>    Well, I seem to have found the answer to my own question, so I thought
>>    I'd email it to the list just in case anyone else needs to know how.
>>    Basically there is an oncontextmenu event for DOM objects.  You can
>>    assign this to a function and put any code you like in there, and then
>>    return false at the end to ensure the event stops and doesn't display
>>    the browser's context menu.  So I added this to my map object to
>>    disable
>>    all browser context menus from appearing on the map like so:
>>    map.div.oncontextmenu = function noContextMenu(e) {return false;};
>>    Seems to work well in both IE and FF (haven't test Opera or on a Mac).
>>    Graham Davis
>>    gdavis at refractions.net <mailto:gdavis at refractions.net>
>>    Graham Davis wrote:
>>    >I'm trying to implement a right-click menu on my map, similar to what
>>    >you see here: http://maps.ask.com/maps.  I've been able to properly
>>    mousedown.
>>    >My problem is that the browser's own right-click menu also
>>    appears, and
>>    >I need to disable or stop this.  I've tried stopping the event from
>>    >propagating in the mousedown function after my code (and in the
>>    mouseup
>>    >function since that is when the browser menu seems to appear) however
>>    >this doesn't stop the browser menu from appearing.
>>    >Has anyone been able to implement a right-click menu on their map
>>    that
>>    >properly disables the browser's right-click menu?
>>    >Also, this might be of importance, but I'm using the vector branch of
>>    >code.  I've noticed that when not using a vector layer, the
>>    right-click
>>    >menu on the map brings up the image menu as you have clicked on
>>    an image
>>    >in the map.  When there is a vector layer overtop, right-clicking
>>    brings
>>    >up the standard browser menu where you can view source and
>>    whatnot, so
>>    >the menus are different.  However, I think any fix for this would
>>    work
>>    >for both (and I have been testing everything I try both with and
>>    without
>>    >a vector layer). So far nothing works.
>>    _______________________________________________
>>    Users mailing list
>>    Users at openlayers.org <mailto:Users at openlayers.org>
>>    http://openlayers.org/mailman/listinfo/users
>>    <http://openlayers.org/mailman/listinfo/users>
>>Robert Buzink, website ontwerp en ontwikkeling
>>Sint-Pietersaalststraat 123
>>9000 Gent
>>+32 (0)9 33 00 267
>>+32 (0)487 548 414
>>post at robertbuzink.nl <mailto:post at robertbuzink.nl>
>>robertbuzink.nl/webdesign <http://robertbuzink.nl/webdesign>
>>Users mailing list
>Users mailing list
Graham Davis
