[OpenLayers-Users] Signatures cutting by tiles
Krinke, Claus
Claus.Krinke at ML.Niedersachsen.de
Mon Feb 26 10:11:47 EST 2007
Hello List,
The image http://www.lrop.niedersachsen.de/FIS-RO/tile_signature.jpg shows
the problem. Signatures are cut off by the tiles. The WMS service is
supplied by the UMN-Mapserver. Is there a solution for the problem?
My layer definition in the html ist:
layers[0] = newWMSlayer("Oberzentren",
"http://10.4.103.89/cgi-bin/mapserv.xml?map=D:/ms4w/Apache/htdocs/gis/ZO.map
", {layers: 'Oberzentren', request:
'getmap',transparent:true,format:'image/png'}, {tileSize: new
OpenLayers.Size(512,512), buffer: 1}, true, false, 1);
layers[1] = newWMSlayer("Mittelzentren",
", {layers: 'Mittelzentren', request:
And the layer definition in the .map file is:
# Start of layer definitions #
LAYER
NAME 'Oberzentren'
TEMPLATE 'Export_Output_OZ_query.html'
DATA 'Export_Output_OZ'
STATUS on
TYPE Point
TRANSPARENCY 100
TOLERANCE 10
TOLERANCEUNITS pixels
SYMBOLSCALE 500000
METADATA
WMS_SRS 'epsg:31467'
WMS_TITLE 'Strukturdaten Oberzentren'
WMS_FEATURE_INFO_MIME_TYPE 'text/html'
END #METADATA
PROJECTION
'init=epsg:31467'
END
LABELITEM 'GEM_NAME'
CLASSITEM 'GEM_NAME'
CLASS
NAME 'Export_Output_OZ'
EXPRESSION /./
STYLE
SYMBOL 'circle'
SIZE 30
COLOR 0 0 0
OUTLINECOLOR -1 -1 -1
END #STYLE
STYLE
SYMBOL 'circle'
SIZE 20
COLOR 254 254 254
END #STYLE
LABEL
TYPE BITMAP
SIZE tiny
COLOR 0 0 0
POSITION UL
ANGLE 0
OFFSET 0 0
END #LABEL
END #CLASS
END #LAYER
LAYER
NAME 'Mittelzentren'
TEMPLATE 'Export_Output_MZ_query.html'
DATA 'Export_Output_MZ'
STATUS on
TYPE Point
TRANSPARENCY 100
TOLERANCE 10
SYMBOLSCALE 500000
METADATA
WMS_TITLE 'Strukturdaten Mittelzentren'
END #METADATA
PROJECTION
'init=epsg:31467'
END
CLASS
NAME 'Export_Output_MZ'
EXPRESSION /./
STYLE
SYMBOL 'circle'
SIZE 20
COLOR 0 0 0
END #STYLE
STYLE
SYMBOL 'circle'
SIZE 13
COLOR 254 254 254
END #STYLE
LABEL
TYPE BITMAP
SIZE tiny
COLOR 0 0 0
POSITION UL
ANGLE 0
OFFSET 0 0
END #LABEL
END #CLASS
END #LAYER
Mit freundlichen Grüßen
Claus Krinke
Niedersächsisches Ministerium
für den ländlichen Raum, Ernährung,
Landwirtschaft und Verbraucherschutz
Telefon: 0511 120-5960
E-Mail: claus.krinke at ml.niedersachsen.de
FAX: 0511 12099-5960
