[OpenLayers-Users] relocating PanZoom Control
bradleyspencer
brad at cubewerx.com.au
Tue Feb 27 18:16:53 EST 2007
Bart,
Thanks for your help but this is not a change that I want to implement nor
do I want to try the one that Graham Davis sent me.
I think the OL developers should implement the same method they implemented
for the panzoom control to the mouse control as you showed me previously
map.addControl(new
OpenLayers.Control.PanZoomBar({div:$('zoomLevelContainer')})); // Pan zoom
bar in Div container
For now I have used double click on the getfeatureinfo listener and it
works just fine but not as transparent as I hade hoped.
Thanks to you and Graham Davis for your suggestions.
Cheers,
Brad Spencer
General Manager
CubeWerx Australia Pty Ltd
ABN: 37 115 163 285
Mob: +61 (0)404 841 131
Tel/Fax: +61 (0)2 9481 7024
mailto:brad at cubewerx.com.au
http://www.cubewerx.com.au
-----Original Message-----
From: Bart van den Eijnden (OSGIS) [mailto:bartvde at osgis.nl]
Sent: Tuesday, 27 February 2007 6:46 PM
To: brad at cubewerx.com.au
Cc: users at openlayers.org
Subject: RE: [OpenLayers-Users] relocating PanZoom Control
Hi Brad,
true, I had to change something for that in the MouseToolbar code, I changed
the initialize function to:
initialize: function(options) {
OpenLayers.Control.prototype.initialize.apply(this, [options]);
which worked for me.
But maybe there is a better way?
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: brad at cubewerx.com.au
Naar: Bart van den Eijnden OSGIS <bartvde at osgis.nl>
Onderwerp: RE: [OpenLayers-Users] relocating PanZoom Control
Datum: 27/02/07 05:32
> Bart,
> Thanks for that I can move the zoom bar but the mouse controls do not
follow
> the same model?
> Cheers,
> Brad Spencer
> General Manager
> ABN: 37 115 163 285
> Sent: Tuesday, 27 February 2007 5:48 PM
> To: brad at cubewerx.com.au; openlayers users
> Subject: Re: [OpenLayers-Users] relocating PanZoom Control
> You can pass in a div id into the constructor, and use css to position the
> div:
> map.addControl(new OpenLayers.Control.PanZoomBar({div:
> Best regards,
> Bart
> http://www.osgis.nl
> Naar: openlayers users <users at openlayers.org>
> Onderwerp: [OpenLayers-Users] relocating PanZoom Control
> Datum: 27/02/07 03:13
> > In Google maps the API allows you to locate the panZoom controls
outside
> > the map by allowing you to anchor to one of the four corners. Is
there a
> similar
> > feature in OpenLayers.
> > &nbsp;
> > I want to do this because I am using a mouse click on the map to do a
> getFeatureInfo
> > request but when I click on the panzoom to do navigate around the map
it
> actually
> > launches off the getFeatureInfo request. So the best way to do this
is to
> move
> > the controls off the map.
> > &nbsp;
> > See http://www.cubewerx.com.au/DemoDrapes.html
> > &nbsp;
> > Cheers,
> > &nbsp;
> > Brad Spencer
> > General Manager
> > ABN: 37 115 163
> > 285
> > Mob: +61 (0)404
> > 841 131
> > Tel/Fax: +61
> > (0)2 9481 7024
> > &nbsp;
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
