[OpenLayers-Users] Can I make the map cover the whole viewport
Pascoe, S (Stephen)
S.Pascoe at rl.ac.uk
Wed Feb 28 09:53:45 EST 2007
> Hi,
> I have to fill the whole viewport with the map. I don't mind panning
if
> necessary to view the whole map, but Iam required not to show any
empty area
> around the map. So everytime the user increases the viewport size, I
need to
> zoom my map automatically so that it covers the entire viewport. How
can I
> achieve this?
I think your problem might be slightly different but I recently found a
solution to preventing users panning the map until it didn't fill the
viewport. I achieved it by inheriting from OpenLayers.Map and
overloading setCenter:
DDCVisMap = OpenLayers.Class.create();
DDCVisMap.prototype = OpenLayers.Class.inherit(OpenLayers.Map, {
setCenter: function(center, zoom, dragging) {
if (center == null) {
center = this.getCenter();
if (zoom == null) {
zoom = this.getZoom();
var resolution = this.baseLayer.resolutions[zoom];
var size = this.getSize();
var w_deg = size.w * resolution;
var h_deg = size.h * resolution;
var bounds = new OpenLayers.Bounds(center.lon - w_deg / 2,
center.lat - h_deg / 2,
center.lon + w_deg / 2,
center.lat + h_deg / 2);
if (bounds.left < -180.0) {
center.lon = center.lon + (-180.0 - bounds.left);
else if (bounds.right > 180.0) {
center.lon = center.lon - (bounds.right - 180.0);
if (bounds.bottom < -90.0) {
center.lat = center.lat + (-90.0 - bounds.bottom);
else if (bounds.top > 90.0) {
center.lat = center.lat - (bounds.top - 90.0);
OpenLayers.Map.prototype.setCenter.apply(this, [center, zoom,
dragging]);
I'm an openlayers newby so it might not be very idiomatic but provided
the maxExtent fills the viewport it seems to work. I'm using
OpenLayers-2.3-rc2.
Stephen Pascoe 01235 445980
British Atmospheric Data Centre
Rutherford Appleton Laboratory, CCLRC
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070228/16e6eb45/attachment.html
