[OpenLayers-Users] non-zooming overviewmap
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Wed Jan 3 12:22:16 EST 2007
Hi Tim,
thanks for the elaborate answer, very helpful.
I tested your approaches, and I got the best results with always
returning true in the isSuitableOverview function.
When I used numZoomLevels=1 the overview map does not zoom, but it does
recenter sometimes, which is also unwanted, at least for my use case.
Another slightly related question, how do I update the overview map?
When I call a mergeNewParams (to update the SLD_BODY parameter to show a
selection in the keymap) on the layer which is in the overview map, the
overview map does not update. It only updates after a zoom or pan in the
main map. How can I trigger an update/drawing event in the keymap? I was
unsuccessful so far with everything I tried.
Thanks again.
Best regards,
Bart
Tim Schaub schreef:
> Hey-
>> how can I get the overviewmap to not zoom in or out? Is this
>> possible using certain values for minRatio and maxRatio? I
>> couldn't figure it out ...
> You can get at this in a number of ways. Just as you could limit the number
> of zoom levels of a regular map, you can limit the number of zoom levels of
> your overview map's map:
> var options = {mapOptions: {numZoomLevels: 1}};
> map.addControl(OpenLayers.Control.OverviewMap(options));
> Note that in this case you might want to use an image layer for your
> overview map's base layer. This also requires the latest from SVN (or just
> update OverviewMap.js [1]).
> You can also hack the min/max ratios:
> var options = {minRatio: 0, maxRatio: Number.POSITIVE_INFINITY};
> map.addControl(new OpenLayers.Control.OverviewMap(options));
> But this isn't really as safe as making the isSuitableOverview function
> always return true:
> var options = {isSuitableOverview: function() {return true;}};
> The first is really the best way. I've updated the wiki to show this
> example.
> Tim
> [1]
> http://trac.openlayers.org/browser/trunk/openlayers/lib/OpenLayers/Control/O
> verviewMap.js?format=raw
> [2] http://trac.openlayers.org/wiki/Control/OverviewMap
>> For now I always return true in the isSuitableOverview
>> function, but that's just a hack.
>> Thanks in advance.
>> Best regards,
>> Bart
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
