[OpenLayers-Users] Problems with OverviewMap
    Hans-Jörg Stark
    h.stark at fhbb.ch
    Fri Jan  5 07:50:10 EST 2007
Ooops!
I just realized my mistake in the code:
instead of     var overview = new OpenLayers.Control.OverviewMap();
I had     var overview = new OpenLayers.Control.OverviewMap({Options:
options});
which didn't do the trick either.
sorry for the mistake, thoug!!
  _____
Von: Hans-Jörg Stark [mailto:h.stark at fhbb.ch]
Gesendet: Freitag, 5. Januar 2007 12:03
An: 'users at openlayers.org.'
Betreff: WG: Problems with OverviewMap
Hi
I would like to put an overview map to my map using projection 'epsg:21781'.
Unfortunately I cannot get it working.
I use the following code:
  <div id="map"></div>
  <script defer="defer" type="text/javascript">
    var map = new OpenLayers.Map('map', { projection: 'epsg:21781',
maxExtent: new OpenLayers.Bounds(606800,262500,619100,272400), units: 'm',
minScale: '100000', maxScale: '5000', scales: ['10000', '75000',
'50000','40000', '30000', '25000', '20000', '15000', '10000', '9000',
'8000', '7000', '6000', '5000'], 'tileSize': new OpenLayers.Size(512,512)
    var myLoc = new OpenLayers.LonLat(7.6,47.558);
    my_wms = new OpenLayers.Layer.WMS( "citymap",
"http://localhost/cgi-bin/mapserv.exe?map=c:/ms4w/apache/htdocs/nafmomNeu/ma
p/citymap.map", {LAYERS: "citymap", format: 'png', transparent:'true'});
    my_wms.setIsBaseLayer(true);
    my_wms.setVisibility(true);
    map.addLayer(my_wms);
    map.addControl(new OpenLayers.Control.LayerSwitcher());
    map.setCenter(myLoc, 13);
    var options = {
        units: 'm',
        numZoomLevels: 1,
        layers: [my_wms.clone()],
        maxExtent: new OpenLayers.Bounds(606800,262500,619100,272400)};
    map.addControl(overview);
    overview.maximizeControl();
  </script>
The main map appears as usual and I can use the zooming, panning, etc.
Though I get the following error message:
bounds has no properties
file:///C:/.../Openlayers/V2.3/OpenLayers-2.3-rc1/lib/OpenLayers/Map.js
Line: 1011
The overviewmap container appears as well  but with no contents. If I click
in it or want to move the red rectangle I get the error:
this.ovmap has no properties
file:///C:/.../OpenLayers-2.3-rc1/lib/OpenLayers/Control/OverviewMap.js
Line: 294
Any help on that?
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070105/69baba76/attachment.html
