[OpenLayers-Users] Tilecache 1.3 problems, mod_python, windows
joanne cook
j.cook at oxfordarch.co.uk
Mon Jan 8 04:22:21 EST 2007
Hi All,
Having had problems getting tilecache to work using cgi, I am now trying using mod_python, under apache 2.2.3. As far as I can tell, mod_python is set up correctly, as I can get a test script to work. However, I am having no luck at all with tilecache. The only alteration I have made to tilecache.cfg is to chance the DiskCache base to /temp/tilecache. I am trying to access the following url:
http://localhost/tilecache-1.3/tilecache.py?LAYERS=basic&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-180,-90,0,90&WIDTH=256&HEIGHT=256
I have also changed the first line of my python files to #!c:/Python25/python.exe -u, which is the location of my python exe file.
I have included the following in my httpd.conf file (I also tried it as an .htaccess file):
<Directory "C:/xampp/tilecache-1.3/">
AddHandler python-program .py
PythonHandler TileCache.Service
PythonOption TileCacheConfig /tilecache.cfg
PythonDebug On
</Directory>
The error I get is this:
MOD_PYTHON ERROR
ProcessId: 508
Interpreter: 'localhost'
ServerName: 'localhost'
DocumentRoot: 'C:/xampp/htdocs'
URI: '/tilecache-1.3/tilecache.py'
Directory: 'C:/xampp/htdocs/tilecache-1.3/'
Filename: 'C:/xampp/htdocs/tilecache-1.3/tilecache.py'
PathInfo: ''
Phase: 'PythonHandler'
Handler: 'TileCache.Service'
File "C:\Python25\Lib\site-packages\mod_python\importer.py", line 1537, in HandlerDispatch
default=default_handler, arg=req, silent=hlist.silent)
File "C:\Python25\Lib\site-packages\mod_python\importer.py", line 1202, in _process_target
module = import_module(module_name, path=path)
File "C:\Python25\Lib\site-packages\mod_python\importer.py", line 304, in import_module
return __import__(module_name, {}, {}, ['*'])
ImportError: No module named TileCache.Service
My concern is that I don't have the path to tilecache.cfg correctly set, or some other pythonpath problem. Given the above setup, what should these values be, or is there some other problem?
Cheers
Jo
Joanne Cook BSc MLitt AIFA MBCS
Information Systems Coordinator
Oxford Archaeology North
This message has been scanned for viruses by BlackSpider MailControl - www.blackspider.com
