[OpenLayers-Users] Overview Map Question
Robert Buzink
post at robertbuzink.nl
Tue Jan 9 15:38:37 EST 2007
hi Tim,
Thanks for the debugging. I know about the adding layers at once. I have
been writing a php class for openlayers. I first added layers to an array
every time a baselayer-var was defined and then outputed the array in an
addlayer-statement at the end of the map, but noticed that openlayers is a
bit picky about the order of statements (adding controls, adding baselayers,
setting center, etc.), so I made it more modular and less
beautiful/efficient.
This shows no overviewmap control at all:
<html>
<head>
<title>Test</title>
<style type="text/css">
#map {
width: 512px;
height: 512px;
border: 1px solid gray;
</style>
<script src="http://dev.virtualearth.net/mapcontrol/v3/mapcontrol.js
" type="text/javascript"></script>
<script src="http://www.openlayers.org/api/OpenLayers.js"></script>
</head>
<body>
<div id="map"></div>
<script defer="defer" type="text/javascript">
var map = new OpenLayers.Map('map');
var virtualearth = new OpenLayers.Layer.VirtualEarth(
"VirtualEarth");
var metacarta = new OpenLayers.Layer.WMS(
"Metacarta",
" http://labs.metacarta.com/wms/vmap0",
{layers: 'basic'});
map.addLayers([virtualearth,metacarta]);
map.addControl (new OpenLayers.Control.OverviewMap());
map.setCenter(new OpenLayers.LonLat(5.69, 50.85), 15);
</script>
</body>
</html>
This creates weird behaviour (1. overviewmap-control, but no overview-map.
2. mouse keeps dragging):
<html>
<head>
<title>Test</title>
#map {
width: 512px;
height: 512px;
</style>
<script src="http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAmbYSvchg-WUKZ1VciMUQehT2yXp_ZAY8_ufC3CFXhHIE1NvwkxTM_U0Wb-HnwWqFxi6YDlhfBryn8w
<http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAmbYSvchg-WUKZ1VciMUQehT2yXp_ZAY8_ufC3CFXhHIE1NvwkxTM_U0Wb-HnwWqFxi6YDlhfBryn8w>"
</head>
<body>
var google = new OpenLayers.Layer.Google("Google Map");
"Metacarta",
"http://labs.metacarta.com/wms/vmap0",
{layers: 'basic'});
map.addLayers([google,metacarta]);
map.addControl(new OpenLayers.Control.OverviewMap());
</script>
</body>
</html>
As you can see, the problem is the baselayer. Whenever it isn't the(/a?) wms
layer, the overviewmap control breaks. Maybe the overviewmapcontrol should
default to the metacarta wms baselayer?
I don't know much about the inside of the ol-api, I am just using the
excellent bricks you provide to build a php/mysql 'application' that
non-technical users can use and configure. Maybe I could do something back
by releasing the php-class when it is finished (if there isn't released one
already)?
Robert,
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070109/d10d90bc/attachment.html
