[OpenLayers-Users] [Users] Help on WFS Example Urgently Required
Jo-V Ng Su Wei
ngsuwei at stee.stengg.com
Wed Jan 10 03:30:54 EST 2007
Any pointers on setting up cgi in Tomcat so that the proxy works?
-----Original Message-----
Sent: Thursday, October 19, 2006 12:26 AM
To: ngsuwei at stee.stengg.com
Cc: Users at openlayers.org
Subject: Re: [Users] Help on WFS Example Urgently Required
FYI:
I have just added this question to the official OpenLayers FAQ:
http://trac.openlayers.org/wiki/FrequentlyAskedQuestions
If there are other questions that anyone out there thinks should be added to
the FAQ, please do not hesitate to edit the wiki yourselves.
(username/password: openlayers/openlayers for those of you without accounts)
On 10/18/06, Erik Uzureau <euzuro at gmail.com> wrote:
> From a previous post by chris schmidt:
> Due to security restrictions in Javascript, it is not possible to
> retrieve information from remote domains via XMLHttpRequest. The way
> to work around this is to set up a local script which can 'proxy'
> information from the remote host. An example script to do this is
> available from the examples directory as proxy.cgi:
> http://svn.openlayers.org/trunk/openlayers/examples/proxy.cgi
> To use WFS results from a remote host on your machine, you must
> install a proxy script somewhere web accessible from the domain you
> plan to use to host your page. You must then edit ProxyHost to match
> that URL: an example URL for most Apache configurations might be:
> OpenLayers.ProxyHost="/cgi-bin/proxy.cgi?url=";
> If the ProxyHost is not set, requests are sent directly. In most
> cases, the result will be a security exception.
> If you are still having problems with this, please send a link to an
> example page on the web where the WFS example fails.
> On 10/15/06, ngsuwei at stee.stengg.com <ngsuwei at stee.stengg.com> wrote:
> > I have downloaded the latest codes using svn. However the WFS
> > example is not working. But the one in the live example is working.
> > Is it because the downloaded code is not latest code as the one in
> > live example or is there any missing configuration at my side? I saw
> > the codes there is this proxy thing, what is this for or do i need
> > to set up one? Immediate help is very appreciated as i am reaching
> > my deadline for the WFS portion to work. Thanks in advance.
> > [This e-mail is confidential and may be priviledged. If you are not
> > the intended recipient, please kindly notify us immediately and
> > delete the message from your system; please do not copy or use it
> > for any purpose, nor disclose its contents to any other person.
> > Thank you.] ---ST Electronics Group---
> > Users mailing list
> > Users at openlayers.org http://openlayers.org/mailman/listinfo/users
