[OpenLayers-Users] size of overview map
Erik Uzureau
euzuro at gmail.com
Thu Jan 11 12:11:37 EST 2007
When you initialize a control, you can pass it a parameter called "options"
if you specify a "size" value (or any other) in the options parameter, it will
overwrite the value statically defined in the class definition.
so:
var options = {
'size': new OpenLayers.Size(50,50)
var oMap = new OpenLayers.Control.OverviewMap(options);
should do it.
hope that helps,
erik
On 1/11/07, Bart van den Eijnden (OSGIS) <bartvde at osgis.nl> wrote:
> Hi list,
> is there another way to change the size of the overviewmap with 2.3RC1 then
> change the size in the js file
> size: new OpenLayers.Size(174, 204)
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
