[OpenLayers-Users] Bug in a alternative text for control icons
    Yves Jacolin
    yjacolin at free.fr
    Wed Jan 24 10:17:47 EST 2007
Le Mercredi 24 Janvier 2007 15:31, vous avez écrit :
> On Wed, Jan 24, 2007 at 03:00:47PM +0100, Yves Jacolin wrote:
> > Le Mercredi 24 Janvier 2007 14:46, vous avez ?crit?:
> > > On Wed, Jan 24, 2007 at 02:34:22PM +0100, Yves Jacolin wrote:
> > > > Hi,
> > > > Controls icons in the map not seems to have alternative text for img
> > > > html tags. However, in the code I can read :
> > > >         btn.alt = title;
> > > > Does it means that it should be display the alt. text ?
> > > I believe that setting the alt attribute on an image should cause it to
> > > display in IE. We should also add the title attribute, which is what FF
> > > uses for hovers. Please feel free to file a ticket on this and a patch,
> > > if you're willing.
> > > Regards,
> > To be correct, the full code is (MouseToolbar.js:81) :
> >         btn.events = new OpenLayers.Events(this, btn, null, true);
> >         btn.events.register("mousedown", this, this.buttonDown);
> >         btn.events.register("mouseup", this, this.buttonUp);
> >         btn.events.register("dblclick", this, OpenLayers.Event.stop);
> >         btn.action = id;
> >         btn.title = title;
> >         btn.alt = title;
> >         btn.map = this.map;
> > So it should be working ! But it is not, with my own configuration. I may
> > be wrong ...
> Right you are. It doesn't work for me either. I don't know why, but it's
> definitely not a new bug. I've just never bothered to look into it. If
> you or anyone else were willing to, that would be great.
> Regards,
More informations about this problem. It seems the btn refers to a div
element ! In the HTML source I get :
<div id="OpenLayers_Control_MouseToolbar_pan" style="position: absolute; left:
5px; top: 308px; width: 28px; height: 28px;" title="Drag the map.">
<img id="OpenLayers_Control_MouseToolbar_pan_innerImage" style="position:
relative; width: 28px; height: 28px;" src="js/img/panning-hand-on.png"/>
</div
The img tag got no alt and title parameters. So the text we can see in IE come
from the div elements.
Y.
Yves Jacolin
http://yjacolin.gloobe.org
