[OpenLayers-Users] Bug in a alternative text for control icons
Yves Jacolin
yjacolin at free.fr
Wed Jan 24 10:32:27 EST 2007
Le Mercredi 24 Janvier 2007 16:20, Christopher Schmidt a écrit :
> On Wed, Jan 24, 2007 at 04:17:47PM +0100, Yves Jacolin wrote:
> > Le Mercredi 24 Janvier 2007 15:31, vous avez ?crit?:
> > > On Wed, Jan 24, 2007 at 03:00:47PM +0100, Yves Jacolin wrote:
> > > > Le Mercredi 24 Janvier 2007 14:46, vous avez ?crit?:
> > > > > On Wed, Jan 24, 2007 at 02:34:22PM +0100, Yves Jacolin wrote:
> > > > > > Hi,
> > > > > > Controls icons in the map not seems to have alternative text for
> > > > > > img html tags. However, in the code I can read :
> > > > > > btn.alt = title;
> > > > > > Does it means that it should be display the alt. text ?
> > > > > I believe that setting the alt attribute on an image should cause
> > > > > it to display in IE. We should also add the title attribute, which
> > > > > is what FF uses for hovers. Please feel free to file a ticket on
> > > > > this and a patch, if you're willing.
> > > > > Regards,
> > > > To be correct, the full code is (MouseToolbar.js:81) :
> > > > btn.events = new OpenLayers.Events(this, btn, null, true);
> > > > btn.events.register("mousedown", this, this.buttonDown);
> > > > btn.events.register("mouseup", this, this.buttonUp);
> > > > btn.events.register("dblclick", this, OpenLayers.Event.stop);
> > > > btn.action = id;
> > > > btn.title = title;
> > > > btn.alt = title;
> > > > btn.map = this.map;
> > > > So it should be working ! But it is not, with my own configuration. I
> > > > may be wrong ...
> > > Right you are. It doesn't work for me either. I don't know why, but
> > > it's definitely not a new bug. I've just never bothered to look into
> > > it. If you or anyone else were willing to, that would be great.
> > > Regards,
> > Hi,
> > More informations about this problem. It seems the btn refers to a div
> > element ! In the HTML source I get :
> > <div id="OpenLayers_Control_MouseToolbar_pan" style="position: absolute;
> > left: 5px; top: 308px; width: 28px; height: 28px;" title="Drag the map.">
> > <img id="OpenLayers_Control_MouseToolbar_pan_innerImage" style="position:
> > relative; width: 28px; height: 28px;" src="js/img/panning-hand-on.png"/>
> > </div
> > The img tag got no alt and title parameters. So the text we can see in IE
> > come from the div elements.
> Ah, naturally. Our "images" are actually images-inside-divs: so, the
> alt/title is on the wrong element. I don't know off the top of my head
> the right way to fix this: I think that the btn has an 'img' property,
> but perhaps we just use btn.firstChild to get to the actual image.
> Regards,
Yes, it works :
---------------- to add ---------------------
btn.firstChild.alt = title;
btn.firstChild.title = title;
just after :
btn.action = id;
btn.title = title;
btn.alt = title;
btn.map = this.map;
Unfortunately, there is another problem :-( The title and alt parameters are
now inside the img tag, but nothing appears when the mouse is on the image.
Y.
Yves Jacolin
http://yjacolin.gloobe.org
