[OpenLayers-Users] any click events in Control.DrawFeature while
drawing polygon
Saverio Rutigliano
saverio.rutigliano at gmail.com
Tue Jun 12 19:13:23 EDT 2007
Richard Duivenvoorde wrote:
> Hi,
> I'm using the DrawFeature control to let users define linestrings. I can
> capture the doubleclick event (for ending the line) using
> lineLayer.onFeatureInsert
> But I cannot find a way to check something WHILE clicking/adding the
> segments. Actually on the addition of every segment I want to be able to
> count the number of segments, because I want to be sure the will be not
> more then 20 segments in certain lines.
OpenLayers.Handler.Path has two callback "done" and "point". The latter
is called for every point added to the path while the user is drawing on
the map.
Here is the "draw-feature.html" example from openlayers distribution
slightly modified to show you how attach your custom defined callback
handler
(see the comment into javascript code)
Regards,
Saverio Rutigliano
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<style type="text/css">
#map {
width: 512px;
height: 350px;
border: 1px solid gray;
#controlToggle li {
list-style: none;
p {
width: 512px;
</style>
<script src="../lib/OpenLayers.js"></script>
<script type="text/javascript">
var map, drawControls;
OpenLayers.Util.onImageLoadErrorColor = "transparent";
function init(){
map = new OpenLayers.Map('map');
var wmsLayer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
"http://labs.metacarta.com/wms/vmap0?", {layers: 'basic'});
var pointLayer = new OpenLayers.Layer.Vector("Point Layer");
var lineLayer = new OpenLayers.Layer.Vector("Line Layer");
var polygonLayer = new OpenLayers.Layer.Vector("Polygon Layer");
map.addLayers([wmsLayer, pointLayer, lineLayer, polygonLayer]);
map.addControl(new OpenLayers.Control.LayerSwitcher());
map.addControl(new OpenLayers.Control.MousePosition());
var options = {handlerOptions: {freehand: true}};
// HERE YOU SPECIFY THE ADDITIONAL callbacks PROPERTY WITH CALLBACK
HANDLER AVAILABLE FOR THE OpenLayers.Handler.Path (i.e. done and point)
var pathDrawFeatureOptions = {
callbacks : {"done": doneHandler, "point":
pointHandler},
drawControls = {
point: new OpenLayers.Control.DrawFeature(pointLayer,
OpenLayers.Handler.Point),
line: new OpenLayers.Control.DrawFeature(lineLayer,
OpenLayers.Handler.Path,
pathDrawFeatureOptions), // specify the custom "pathDrawFeatureOptions"
polygon: new OpenLayers.Control.DrawFeature(polygonLayer,
OpenLayers.Handler.Polygon, options)
for(var key in drawControls) {
map.addControl(drawControls[key]);
map.setCenter(new OpenLayers.LonLat(0, 0), 3);
document.getElementById('noneToggle').checked = true;
// HERE YOU SPECIFY THE CALLBACK HANDLERS: doneHandler() CALLED WHEN
USER FINISHES THE PATH AND pointHandler() CALLED FOR EVERY POINT ADDED
// BTW: console.log IS THE FIREBUG METHOD TO WRITE DIRECTILY TO THE
CONSOLE... JUST FOR DEBUG
function doneHandler(lineGeom) {
console.log("doneHandler:" + lineGeom.getComponentsString());
var gPointCount = 0;
function pointHandler(aPoint) {
gPointCount++;
console.log("pointHandler:point n." + gPointCount + " geom =
" + aPoint.toShortString());
function toggleControl(element) {
for(key in drawControls) {
var control = drawControls[key];
if(element.value == key && element.checked) {
control.activate();
} else {
control.deactivate();
</script>
</head>
<body onload="init()">
<h1>OpenLayers Draw Feature Example</h1>
<div id="map"></div>
<ul id="controlToggle">
<li>
<input type="radio" name="type" value="none" id="noneToggle"
onclick="toggleControl(this);" checked="checked" />
<label for="noneToggle">navigate</label>
</li>
<li>
<input type="radio" name="type" value="point"
id="pointToggle" onclick="toggleControl(this);" />
<label for="pointToggle">draw point</label>
</li>
<li>
<input type="radio" name="type" value="line" id="lineToggle"
<label for="lineToggle">draw line</label>
</li>
<li>
<input type="radio" name="type" value="polygon"
id="polygonToggle" onclick="toggleControl(this);" />
<label for="polygonToggle">draw polygon</label>
</li>
</ul>
<p>Feature digitizing is in freehand mode by default. In freehand
mode, the mouse is treated as a pen.
Drawing begins on mouse down, continues with every mouse move, and
ends with mouse up.</p>
<p>To turn freehand mode off, hold down the shift key while
digitizing. With freehand mode off, one
vertex is added with each click and double-clicks finish drawing.
Freehand mode can be toggled on and off
at any time while drawing.</p>
</body>
</html>
