[OpenLayers-Users] Switching a layer between tiled and untiled
behaviour
Christopher Schmidt
crschmidt at metacarta.com
Sat Mar 3 09:56:28 EST 2007
On Sat, Mar 03, 2007 at 08:53:03AM +0000, Jon Blower wrote:
> Hi all,
> I suspect the answer to this is probably "no" but is there a way to
> switch a certain WMS layer between tiled and untiled behaviour at
> runtime?
I'm not really sure hwy you'd want to do it, but you could probably have
two layers, and then make turning them on or off change the state to the
other layer type.
However, a WMS Untiled layer is no different than any other layer
(WorldWind, Ka-Map, etc.) -- there is no inherent connection between a
layer and its untiled cousin, so the answer is, as you suspected, 'no'.
If you could explain your use case more completely, I might be able to
understand your question better and give a better answer.
Regards,
Christopher Schmidt
MetaCarta
