[OpenLayers-Users] Mouse.Default help
bradleyspencer
brad at cubewerx.com.au
Sun Mar 4 17:56:40 EST 2007
Christopher,
Sorry to do this but I am unable to get this working.
I am using the following code to make double click work as a getFeatuerInfo
request but double click on the map still re-centres the map?
OpenLayers.Control.MouseDefaults.prototype.defaultDblClick = function(e)
var getFeatureInfoRequest = landuse.getFullRequestString
REQUEST: "GetFeatureInfo",
//EXCEPTIONS: "application/vnd.ogc.se_xml",
EXCEPTIONS: "bxfs",
BBOX: landuse.map.getExtent().toBBOX(),
X: e.xy.x,
Y: e.xy.y,
INFO_FORMAT: 'text/html',
QUERY_LAYERS: landuse.params.LAYERS,
QUERY_LAYERS: queryLayers ,
WIDTH: landuse.map.size.w,
HEIGHT: landuse.map.size.h
makePopup(getFeatureInfoRequest,'1200','480','both');
Event.stop(e);
FF is not objecting to this code. Is there something I am doing obviously
wrong here?
The application can be tested at http://demo.cubewerx.com.au/DemoDrapes.html
Thanks in advance.
Cheers,
Brad Spencer
General Manager
CubeWerx Australia Pty Ltd
ABN: 37 115 163 285
Mob: +61 (0)404 841 131
Tel/Fax: +61 (0)2 9481 7024
mailto:brad at cubewerx.com.au
http://www.cubewerx.com.au
-----Original Message-----
From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
Sent: Sunday, 4 March 2007 1:27 PM
To: bradleyspencer
Cc: openlayers users
Subject: Re: [OpenLayers-Users] Mouse.Default help
On Sun, Mar 04, 2007 at 12:47:48PM +1100, bradleyspencer wrote:
> I am not a trained Object Oriented programmer so I apologise for this dumb
> question.
> I want to suppress the use of doubleClick on the map as a re-centre
> operation and use it as a getFeatureInfo operation instead.
> To do this the doco says I need to ?create a subclass of MouseDefaults,
> replacing the functions whose behavior you wish to change?.
> There are no examples of this and whilst I have made an event listener to
do
> the getFeatureInfo quite successfully, I am not at all sure how to make a
> new subclassof MouseDefaults as stated and link this event into that
> subclass.
If you only want to do it for one control (for example, when you only
have one map in the page):
control = new OpenLayers.Control.MouseDefaults();
control.defaultDblClick = function(evt) {
var point = this.map.getLonLatFromViewPortPx( evt.xy );
alert("Got point:" + point);
OpenLayers.Event.stop(evt);
return false;
If you have multiple maps, or don't want to change the default controls
when creating the map:
OpenLayers.Control.MouseDefaults.prototype.defaultDblClick = function(evt)
return false;
Regards,
Christopher Schmidt
MetaCarta
