[OpenLayers-Users] displaying Features
Eric Lemoine
Eric.Lemoine at camptocamp.com
Wed Mar 7 09:23:10 EST 2007
On 3/7/07, Eric Lemoine <Eric.Lemoine at camptocamp.com> wrote:
> On 3/6/07, Keith <kweber at archetypecorp.com> wrote:
> > I've been playing around with the feature object, but I can't get the marker
> > attribute to display on the map.
> > I suspect that this is because I don't know the correct method for adding a
> > feature to a layer. This seems like a trivial problem, but I haven't found
> > a function that straight up adds a feature to the layer. I have included a
> > "dumbed-down" version of the code I'm working with below.
> > I'm hoping to use the feature as the object in the event register call, so
> > that I can access its attributes doing the mousedown event. I'd be very
> > appreciative if someone can clue me into how to accomplish this.
> > Am I missing anything else?
> For markers, you must crea
[Hit the send button to fast]
For markers, you must use a layer of type OpenLayers.Layer.Markers.
Then you can add your markers using that layer's addMarker() method.
Hope this helps,
Eric
