[OpenLayers-Users] A bug in Openlayers 2.3!
Erik Uzureau
erik.uzureau at metacarta.com
Tue Mar 13 13:16:04 EDT 2007
Thank you for the bug report Nguyen. Hopefully you can
use the fix in trunk for this problem. Sorry for the inconvenience... 2.4 is
on its way and will be much cleaner :-)
erik
On 3/13/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> On Tue, Mar 13, 2007 at 01:49:10AM -0700, Nguyen Thi Van An wrote:
> > Hi all,
> > I've just downloaded Openlayers 2.3 and ran some examples. I installed
> > Firebug of Mozilla to find out if a web page have a bug. When I run example
> > "baseLayers.html", I get an error from Firebug:
> > this.map has no properties
> > (this.viewRequestID == this.map.viewRequestID)) {
> > Util.js (line 235)
> > All file involved with file "Util.js" have the same error. Any suggestion
> > for me ?
> This is a bug which is fixed in trunk, it was found shortly after
> releaseing 2.3. With the upcoming 2.4 release, we had decided to not
> push out another 2.3 release, since it's extra time that would end up
> being wasted. For now, you can use SVN: if you don't have the tools to
> get code directly from SVN, I can help you by building a tarball or
> zipfile. Let me know.
> Regards,
> Christopher Schmidt
> MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
