[OpenLayers-Users] IE weirdness
Eric Lemoine
Eric.Lemoine at camptocamp.com
Wed Mar 21 10:32:52 EDT 2007
On 3/21/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> On Wed, Mar 21, 2007 at 03:21:37PM +0100, Eric Lemoine wrote:
> > Hi list
> > I've experienced weird things with OL in IE (version 7).
> > The following examples are all based on examples/lite.html.
> > This works:
> > <body onload="init()">
> > <table><tr><td>
> > <div id="map"></div>
> > </td></tr></table>
> > </body>
> > This works:
> > <body>
> > <script type="text/javascript">
> > init();
> > </script>
> > </body>
> > This does NOT work:
> > <body>
> > <table><tr><td>
> > init();
> > </script>
> > </td></tr></table>
> > </body>
> When you say 'does not work': can you be more specific? is it that the
> map doens't display correctly, or is it that there is a Javascript error?
IE doesn't display the map, but doesn't show any js error.
> I never put the script anywhere but the <head> of the page because there
> are plenty of issues doing anything else. In this case, your init() is
> probably being called before the end of the table has had a chance to
> load, and as a result, the map has no width/height when it's
> initialized, and thus it doesn't show up correctly after initializing.
I see.
> Is there a specific reason you need to do it hte way you are?
Well, the <head> is in a template file, which is also included in
pages that don't display maps.
Thanks a lot,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
