[OpenLayers-Users] click events
Robert Buzink
post at robertbuzink.nl
Fri Mar 23 10:12:22 EDT 2007
hi,
I have two problems with clickevents
1. When a popup and a click event are combined in the script, it is
impossible to close the popup using the close-button. Clicking on the close
button will just trigger the click-event. This happens in IE, not in FF. I
made a ticket under http://trac.openlayers.org/ticket/555. In the attachment
of this ticket you will find a simple example.
2. When a clickevent is defined, it gets activated when you click the
PanZoom <http://trac.openlayers.org/wiki/PanZoom> control. It should only be
activated when clicking in the map, not when clicking the controls. This is
only true for version 2.3, earlier openlayers versions did not show this
behavior. I made a ticket under http://trac.openlayers.org/ticket/554.
Example: http://openlayers.org/dev/examples/click.html
Robert Buzink, website ontwerp en ontwikkeling
Sint-Pietersaalststraat 123
9000 Gent
+32 (0)9 33 00 267
+32 (0)487 548 414
robertbuzink.nl/webdesign
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070323/04949270/attachment.html
