[OpenLayers-Users] printing...
John Cole
john.cole at uai.com
Sat Mar 24 15:37:14 EDT 2007
Steve,
Yea, our current IMS based app does that, but I was hoping to avoid that
method; all that duplicating complex code and such. I'll check out ka-map,
I haven't played with that in a while, so I don't remember how it's doing
it.
I've have most of the printing stuff worked out with css, except for the
map itself. I was hoping for an elegant solution :-)
Thanks,
John
-----Original Message-----
From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
Sent: Saturday, March 24, 2007 1:20 PM
To: John Cole
Cc: 'Christopher Schmidt'; openlayers
Subject: Re: [OpenLayers-Users] printing...
John,
Another approach is to render a new page the does the print layout on it
and to use mapserver to render a single image equivalent of what is
being displayed in open layers. You also might want to take a look at
what ka-map is doing for the printing.
-Steve W
John Cole wrote:
> Printing to a pdf via mapserver is ideal when you only need the map
output,
> but when dealing with the contents of a web based application, the map is
> rarely the sole contents of the page.
> In my case, I have additional information associated with the map that
needs
> to be included in the report, which rules out using mapserver's pdf
output.
> I'll also have to create a legend which isn't supported with a mapserver
> pdf.
> I tried my idea of having two maps and div tags, turning one off with the
> screen stylesheet and vice versa with the print sytlesheet, but apparently
> the OL map object overrides the display value of the div tag, turning both
> on at the same time.
> As another approach, I was thinking of just having a div tag and setting
> it's background image property to the value of a WMS request pulled from
one
> of the layers. I believe that I will have to have a print button in order
> to have JS turn off the map visibility so that it will be replaced by the
> div with the wms background when using the print stylesheet. I'd love to
> get this working just through the stylesheets, since then users could
simply
> use the browsers file->print rather than rely on a page element (I know
I'll
> get calls about file-print not working :-) )
> Still open to suggestions though!
> John
> From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
> Sent: Saturday, March 24, 2007 11:46 AM
> To: John Cole
> Cc: openlayers
> On Sat, Mar 24, 2007 at 10:14:58AM -0600, John Cole wrote:
>> What is the easiest way of getting OL to configure itself for printing?
> The
>> issue I have is that when printing with overlays and controls, the base
> map
>> gets covered and doesn't show (try a print preview on one of the example
>> pages with multiple layers).
>> So far, my only idea is to have two maps defined, one with a single layer
>> that is only enabled in the print stylesheet while the other is disabled,
>> and have some JS to keep the two in sync. Any other suggestions?
> I highly recommend not depending on browsers for printing.
> Instead, I recommend using some other tool to render a PDF out of your
> backend: MapServer, for example, has a PDF output. Using PDF output
> (instead of browser-based printing) means that your renderer is in
> control of styling of the map, and you don't have the issues with
> overlays or anything else.
> http://mumbai.freemap.in/ uses this technique.
> That's always been my recommendation, and I'm sticking to it :)
> Regards,
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.5.446 / Virus Database: 268.18.17/731 - Release Date: 3/23/2007
3:27 PM
No virus found in this outgoing message.
3:27 PM
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the sender. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
