[OpenLayers-Users] OL 2.3 issue with MS Ajax UpdatePanel...
John Cole
john.cole at uai.com
Sat Mar 24 20:10:03 EDT 2007
To reply to my own question :-)
Banging around on this, it seems that the UpdatePanel is calling the
PageLoad function each time it is executed. Not sure why, but I've put in a
check to see if my 'map' variable has been set and this prevents the map
from being init'ed multiple times.
In any case this is an interesting side effect.
John
-----Original Message-----
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On
Behalf Of John Cole
Sent: Saturday, March 24, 2007 3:45 PM
To: openlayers
Subject: [OpenLayers-Users] OL 2.3 issue with MS Ajax UpdatePanel...
I've gotten OL to work with an MS Ajax enabled web site, well, that is until
now. I've run into an issue with the UpdatePanel. I've created a sample
website that shows the issue.
I have a dropdown list of states, that uses the UpdatePanel to hide the
postback to populate the list of counties and enable the second dropdown.
However, the update panel is causing a copy of the map to be appended to the
bottom of the page each time you select a value from the first drop down
list.
You can see it here: http://issues.uai.com:81/oltest/default.aspx
I've used other parts of the MS ajax kit, and haven't had any problems till
now. Since there are possible issues between prototype.js and the MS ajax
library, I've been on the lookout for issues, but it didn't appear that OL
was using any of the prototype.js stuff that broke ms ajax. I'd really like
to be able to use the update panel :-) Any suggestions would be appreciated.
Thanks,
John
No virus found in this outgoing message.
Checked by AVG Free Edition.
Version: 7.5.446 / Virus Database: 268.18.17/731 - Release Date: 3/23/2007
3:27 PM
This email and any files transmitted with it are confidential and intended
solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the sender. This
message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not
disseminate, distribute or copy this e-mail.
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
No virus found in this incoming message.
3:27 PM
3:27 PM
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the sender. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
