[OpenLayers-Users] click events
Eric Lemoine Eric.Lemoine at camptocamp.com
Tue Mar 27 01:07:58 EDT 2007
On 3/27/07, Eric Lemoine <Eric.Lemoine at camptocamp.com> wrote:
> On 3/23/07, Robert Buzink <post at robertbuzink.nl> wrote:
> > hi,
> Hi Robert!
> > I have two problems with clickevents
> > 1. When a popup and a click event are combined in the script, it is
> > impossible to close the popup using the close-button. Clicking on the close
> > button will just trigger the click-event. This happens in IE, not in FF. I
> > made a ticket under http://trac.openlayers.org/ticket/555.
> > In the attachment of this ticket you will find a simple example.
> > 2. When a clickevent is defined, it gets activated when you click the
> > PanZoom control. It should only be activated when clicking in the map, not
> > when clicking the controls. This is only true for version 2.3, earlier
> > openlayers versions did not show this behavior. I made a ticket under
> > http://trac.openlayers.org/ticket/554. Example:
> > http://openlayers.org/dev/examples/click.html
> What browser? The click.html example works fine on my FF/Linux.
Nevermind, I also have the problem.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
