[OpenLayers-Users] easiest way to get collection of coordinates
from drawn vectors
Tim Schaub
noreply at geocartic.com
Wed Mar 28 15:30:18 EDT 2007
Hey Mike-
Mike Quentel wrote:
> I had a look at the API and the FAQ, but I've not
> figured out how to obtain the vertices of a polygon or
> polyline; however, I see there is a getX, getY, and
> toString set of functions for a point (Point.js).
I think you've already figured this out, but a point has getX and getY -
everything else is a collection with components. For a line string,
components is an array of points. For a polygon, components is an array
of linear rings (linear rings are line strings where the last point and
the first point are the same point).
If you want to get coordinate information about a digitized feature from
within your application, then you will probably want to dig into the
components array.
If you want to transfer coordinate information to another client, then
you should use one of the existing formats. See OpenLayers/Formats for
your current options. I'll be adding well-known text (WKT) to that list
shortly.
Tim
PS- I'm also going to advocate for the removal of getX and getY (and
setX, setY) from point geometries - this is an unnecessary inefficiency.
It means that points would not have lon and lat properties (only x and
y) - but I think this is the right way to go anyway.
