[OpenLayers-Users] Which OpenLayers.Feature.Vector.style is
used while drawing?
Tim Schaub
noreply at geocartic.com
Fri Mar 30 20:38:43 EDT 2007
Hey-
Lance Dyas wrote:
> Speaking of this how would you capture the "done" event after the user
> draws a feature?
You have two options.
If you want to let the DrawFeature control do it's job and get notified
after a feature has been added, construct your control with options like:
function myFunction(feature) {
// do something after a feature is added
var options = {featureAdded: myFunction};
var control = new OpenLayers.Control.DrawFeature(lineLayer,
OpenLayers.Handler.Path, options);
If you want to stop the feature from being added in the normal way and
do something else with it, you modify the callbacks that get sent to the
handler like:
function myFunction(geometry) {
// do something before the new feature is created
var options = {callbacks: {done: myFunction}};
> And is decent measuring tool already in the works by somebody?
In the works.
Tim
