[OpenLayers-Users] wms untiled 'busy loading' message or image
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Thu May 3 07:58:08 EDT 2007
Hi Richard,
there is for WMS.Untiled only:
var layerloadcounter = 0;
var activitydiv;
mylayer.events.register( 'loadend', this, decreasecounter);
mylayer.events.register( 'loadcancel', this, decreasecounter);
mylayer.events.register( 'loadstart', this, increasecounter);
function increasecounter()
  layerloadcounter++;
  if (layerloadcounter > 0 && activitydiv)
    activitydiv.style.visibility = "visible";
function decreasecounter(){
  if (layerloadcounter > 0) layerloadcounter--;
  if (layerloadcounter == 0 && activitydiv)
    activitydiv.style.visibility = "hidden";
And then have some kind of div in the center of the map div:
function activitylayerinit()
  sz = new OpenLayers.Size();
  sz.h = gMapDHTMLWaitImageHeight;
  sz.w = gMapDHTMLWaitImageWidth;
  var dim = OpenLayers.Element.getDimensions(map.viewPortDiv);
  position =
    new OpenLayers.Pixel(dim.width-gMapDHTMLWaitImageWidth-25,
      gMapDHTMLWaitImageHeight);
    activitydiv = OpenLayers.Util.createDiv("ActivityLayer",
      position, sz, gMapDHTMLWaitImage);
    activitydiv.style.zIndex = 1000;
    map.viewPortDiv.appendChild(activitydiv);
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Richard Duivenvoorde <rdmailings at duif.net>
Naar: users at openlayers.org <users at openlayers.org>
Onderwerp: [OpenLayers-Users] wms untiled 'busy loading' message or image
Datum: 03/05/07 09:40
> Hi List,
> What is the preferred way to implement some kind of 'loading or busy
> message' for a slow wms server?
> I've got a map with some (faster) tiled reference layers, and one (slow)
> untiled wms top layer. While the reference layer loads pretty fast, the
> (dynamic) top layer is sometimes loaded after a few seconds. I want to
> inform users that they have to be patient for a while :-)
> If there is some kind of callback mechanisme possible which is called
> when the image is loaded? So I can show an image while loading, and
> remove it when this callback function is called.
> TIA
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
