[OpenLayers-Users] Object orientated map interface
John Westwood
John.Westwood at port.ac.uk
Thu May 3 12:02:42 EDT 2007
Awesome, that works perfectly.
Thanks very much Ezequiel!
Regards,
John W.
John Westwood
Research Assistant
Great Britain Historical GIS Project
Department of Geography, University of Portsmouth
Buckingham Building, Lion Terrace, Portsmouth PO1 3HE
GIS Project Office: (023) 9284 2500
>>> "Ezequiel Gonzalez Rial" <gonrial at gmail.com> 03/05/2007 16:47 >>>
John,
I recommend you to split your map into different divs and when you call
your
function, pass them as parameters. Using your files I could make it
work.
I copy the modified lines:
HTML:
17: newMap1 = new EmbeddedMap('map');
19: newMap2 = new EmbeddedMap('map2');
+31: <div id="map2"></div>
Javascript:
1: function EmbeddedMap(div)
3: var map = new OpenLayers.Map(div);
Hope you can use it this way.
Best Regards
Ezequiel Gonzalez Rial (gonrial at gmail.com)
