[OpenLayers-Users] What is serving examples/openmnnd.html?
Andrew Larcombe
andrew at andrewlarcombe.co.uk
Fri May 11 06:17:15 EDT 2007
On 9 May 2007, at 14:45, Fischer, Brian wrote:
> Steve is right it is a custom solution developed with MySQL and
> some C code by LMIC. I will talk with my contacts their and see if
> I can do anything to try to get them to share the code. The speed
> is very impressive. The one limitation is it only supports the
> projection the image is currently stored in.
Providing you've got limitations and you've got your creative hat on
there are lots of nice optimisations you can do. I recently put
together a wms service for 14TB of 25cm resolution air photos.
Luckily the wms client being used had a fixed window size and fixed
resolutions that it was going to view at, hence I was able to ramp up
the optimisation by feeding the wms server pre-generating lower
resolution overviews that I knew the client was going to request as
tiled tiffs, each tile's being the size of the image the client was
going to request and the tile's data being jpeg compressed. A lot of
optimisation, but with a relatively static dataset optimising the
input data to the wms server can really pay off.
Cheers,
Andrew
Andrew Larcombe
Freelance Geospatial, Database & Web Programming
web: http://www.andrewlarcombe.co.uk
email: andrew at andrewlarcombe.co.uk
icq: 306690163
