[OpenLayers-Users] Storing vectors in OL
Przemysław Bojczuk
pb at gis.umcs.lublin.pl
Fri May 11 07:16:10 EDT 2007
Hello!
Andrew Larcombe wrote:
> You should be able to create a function which posts your drawn object
> to a server where you can, for example, store it in a database for
> future use. eg for a box you could do something like this (warning,
> this code may not work ootb):
That's a great hint, though I would rather to only send the final
effect, for example by pushing a button. If is send it 'live' (as
I understand putting the instructions in onBoxDrawn does just it),
then what about if someone changes the vertex position?
And it still leaves me with a problem of how to accomplish storing the
vectors (PostGIS maybe, but I haven't used it all that much).
Anyway, your post helped me greatly to follow what I believe to be the
right direction. Thanks!
Of course any other comments will still be appreciated. :-)
PB
Geographical Information Systems Laboratory
Institute of Earth Sciences, UMCS
http://gis.umcs.lublin.pl/en/
