[OpenLayers-Users] Problem with calling default mouse down
handler (2.4)
Pierre GIRAUD
bluecarto at gmail.com
Fri May 18 02:15:42 EDT 2007
If you are currently using the 2.4 version I advice you to have a look
at examples/click.html
That way you'll be able to register a "click" event on the map and do
anything you with a callback.
However, you might prefer to have no default controls activated on the
map (http://trac.openlayers.org/wiki/FrequentlyAskedQuestions#HowdoImakeanOpenLayersmapwithoutanycontrols)
and then create yours by creating a control that inherits from
OpenLayers.Control or extends it (examples/custom-controls.html).
I'm not sure this answers your questions but I hope this helps.
Regards
Pierre
On 5/18/07, Nick Whitelegg <nick at hogweed.org> wrote:
> Hello everyone,
> I want to override a mouse down event on a map. Previously (in 2.2) I used
> code such as:
> function mouseDownHandler(e)
> mouseIsDown = true;
> map.controls[0].defaultMouseDown(e);
> if(e.preventDefault)
> e.preventDefault();
> return false;
> However, now (2.4, trunk SVN version) I get the error:
> Error: map.controls[0].defaultMouseDown is not a function
> Source File: http://www.free-map.org.uk/freemap/javascript/vector/init.js
> Line: 195
> What do I need to do now to call the default mouse down action?
> Thanks,
> Nick
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
