[OpenLayers-Users] design advice
    Roger Kunkel
    rakunkel at ucdavis.edu
    Wed May 30 12:19:21 EDT 2007
Thanks,
I have seen the mergeNewParams() method mentioned in this list
before. I'm a little unclear on how to apply to to a WFS layer with a
Filter param.
Anyone have an example?
On May 30, 2007, at 5:41 AM, Pierre GIRAUD wrote:
> Did you try having something similar to WMS reload hacks. I mean using
> mergeNewParams() with a randomized parameter.
> http://openlayers.org/pipermail/users/2007-April/001455.html
> You may also have a look at the refresh method available for vector
> layers.
> Regards.
> Pierre
> On 5/30/07, Roger Kunkel <rakunkel at ucdavis.edu> wrote:
>> Hi,
>> I'm in need of some design advice.
>> My application uses a vector layer created via a WFS call with a
>> Filter to
>> query and display intersecting geometries.
>> This generally works well, but I need to alter the Filter and
>> reload the
>> result frequently. So far, I've been destroying the
>> vector layer and creating a new one each time. Is this an inefficient
>> approach? and what sequence of methods should I use?
>> I noticed there is a removeFeatures() and a destroyFeatures()
>> function in
>> vector.js.
>> Should I just use destroy() and recreate the layer or use
>> removeFeatures()
>> and somehow reload the layer.
>> I also use the selectFeature control - should it also be destroyed
>> and
>> recreated.
>> Thoughts and sample code appreciated.
>> Roger Kunkel
>> CERES Program
>> Dept. of Land Air & Water Resources
>> UC Davis
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
Roger Kunkel
CERES Program
UC Davis
