[OpenLayers-Users] Meta layer and Partial labels
Jackey Cheung cheung.jackey at gmail.com
Thu May 31 01:48:16 EDT 2007
I did, and labels are quite normal until I use the meta layer.
----- Original Message -----
From: "Stephen Woodbridge" <woodbri at swoodbridge.com>
To: "Jackey Cheung" <cheung.jackey at gmail.com>
Cc: <users at openlayers.org>
Sent: Thursday, May 31, 2007 12:13
Subject: Re: [OpenLayers-Users] Meta layer and Partial labels
> Jackey Cheung wrote:
>> Greetings.
>> using meta layers helps me combat the edges effects, but after I used
>> meta layers, labels are broken. many of the labels are partially
>> invisible at the edge of tiles. is there any way to fix this issue? do I
>> have to separate the labels into a different layer?
> If you are using mapserver to generate the images, set PARTIALS FALSE in
> the LABEL block.
> -Steve W
