[OpenLayers-Users] strange click events with internet explorer
percy
percyd at pdx.edu
Thu May 31 13:42:08 EDT 2007
This sounds similar to a problem I had last October. I think it was
fixed in version 2.2, I'll paste the email below...
Percy
-------- Original Message --------
Subject: Re: [OpenLayers-Users] "interesting" cross browser problem
with mouse click position
Date: Fri, 27 Oct 2006 11:09:34 -0700
To: Christopher Schmidt <crschmidt at metacarta.com>
CC: users at openlayers.org
References: <20061011160003.A6010EDFAF at rainier.metacarta.com>
<45401072.3020304 at pdx.edu> <20061026143712.GB15808 at metacarta.com>
that fixed it, thanks!
any idea when 2.2 will become the "stable" release?
I just got the SVN version out yesterday and was playing with that SWEET
new MousePosition control. I need to wait to put that on our production
server until it gets blessed, though.
Thanks again for the groovy interface,
Percy
Christopher Schmidt wrote:
> On Wed, Oct 25, 2006 at 06:33:38PM -0700, percy wrote:
>> Hi All,
>> We are attempting to use an openlayers frontend to a kamap tiled
backend.
>> My test page, http://ngmdb.usgs.gov/ol/examples/ngmdb4.html , works
>> great in both "major" browsers. However when we integrate it into the
>> main search page (which is not yet on a public site, but here's a
>> simpler Kamap version: http://ngmdb.usgs.gov/ngm_compsearch_map.html) we
>> get errant behaviour with regard to how the mouseclicks are handled by
>> OpenLayers in FireFox!
>> to see this in action, just edit your test file by sticking in this div
>> just after the body tag:
>> <div style="width:600px;height:800px;background-color:#008800;">
>> Push the map down the screen
>> </div>
>> and then load the test file in a browser. firefox will exhibit the same
>> breaking behavior as it does on the working page!"
> Mistakenly sent my response to Percy, rather than to the list: This was
> fixed with r1692, http://trac.openlayers.org/changeset/1692 closing bug
> #333, http://trac.openlayers.org/ticket/333 , and the patch available at
> the bottom of the page on r1692 should allow you to fix this issue for
> older OpenLayers instances. Alternatively, this fix is included in the
> 2.2-rc1 currently being tested, and will be included in the final 2.2
> release.
> Regards,
> On Thu, May 31, 2007 at 11:00:08AM +0200, Christian Sengstock wrote:
>> Is this a known problem and is there maybe a workaround? I think the
>> problem depends on where the map div is located in the DOM, because it
>> worked properly when i tested the MouseToolbar with a very basic html
>> page (just the map div).
> I'm not aware of this problem, or a workaround. (This just means I
> haven't run into it, largely because I mostly use simple DOMs :))
> Anyone else run into this issue?
> Regards,
David Percy
Geospatial Data Manager
Geology Department
Portland State University
http://gisgeek.pdx.edu
503-725-3373
