[OpenLayers-Users] vector questions
Mick Jagger lists at jpw.biz
Thu May 31 23:23:49 EDT 2007
> This is http://trac.openlayers.org/ticket/658, "Vector layer does not
> work with Google". There is information in that ticket on how to check
> out some code that doesn't suffer this problem.
This code in the ticket worked, and kept the polygon in place when I panned around the map.  However interestingly enough, it caused a problem with the code referenced below to create a circle with multiple polygon segments.  With the stock openlayers 2.4 the circle looks fine.  But with this new code, it becomes an oval that is distended in the y direction on the map.  Using other layers such as WMS or Yahoo didn't have this problem, just google.
> http://openlayers.org/pipermail/users/2007-May/001577.html is probably
> Instead, you draw a many-sided polygon.
lists at jpw.biz
