[OpenLayers-Users] overview control
Huub Fleuren huub.fleuren at geodan.nl
Fri Nov 2 09:09:15 EDT 2007
It appears to be so that the options for the overviewmapcontrol must be
set like
var overviewrd = new OpenLayers.Control.OverviewMap({mapOptions:optionsrd});
Thanks Steven for pointing this out
Even if I read carefully in de docs i suppose that this is documented.
Howefer: in the overviewmap.html example it looks like:
    var overview = new OpenLayers.Control.OverviewMap(options);
Allthough this also works in this case I would suggest that this will be
corrected in de distribution
Regards,
Huub
Huub Fleuren wrote:
> Hi,
> I'm not sure but pretty sure that the overviewcontrol for a projection
> like 28992 does not work correctly (it does for 4326). What is a good
> way to go forward with this? Maybe file a trac-ticket?
> I' referring to my previous contributions in this thread ...
> I tried using only different options (for the map and the
> overview)-(holding this carefully the same), it boils down to the units,
> i guess.
>   var optionsll = {
>      projection: "EPSG:4326"
>     ,maxExtent: new OpenLayers.Bounds( 3.13, 50.45, 7.14,53.32)
>     ,maxResolution: 1500
>     ,scales:[2500000, 1200000, 600000, 300000, 150000, 75000, 37000,
> 12500, 4250]
>   var optionsrd = {
>      projection: "EPSG:28992"
>     ,units:"m"
>     ,maxExtent: new OpenLayers.Bounds( 0,300000,250000,650000)
> 12500, 4250]
> Regards, Huub
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
