[OpenLayers-Users] overview control
Tim Schaub
tschaub at openplans.org
Fri Nov 2 14:35:25 EDT 2007
In hopes that these links show up at the top of the google search
results for OverviewMap, I'll gather doc links here:
If you have trouble with the overview map control, please read:
http://trac.openlayers.org/wiki/Control/OverviewMap
If you want to set custom map options on the overview map control, find
the bit on "Custom map options" on that page.
http://trac.openlayers.org/wiki/Control/OverviewMap#Custommapoptions-projectionsextentsetc.
If you like reading class documentation, please read:
http://dev.openlayers.org/apidocs/files/OpenLayers/Control/OverviewMap-js.html
If you want to see the bit where it describes the mapOptions property,
click on the mapOptions property.
http://dev.openlayers.org/apidocs/files/OpenLayers/Control/OverviewMap-js.html#OpenLayers.Control.OverviewMap.mapOptions
If you want to learn by reading code and don't own a text editor, see
http://trac.openlayers.org/browser/trunk/openlayers/lib/OpenLayers/Control/OverviewMap.js
Specifically, you can read about the mapOptions property:
http://trac.openlayers.org/browser/trunk/openlayers/lib/OpenLayers/Control/OverviewMap.js#L68
Or, if you look a few lines farther down, you can read about the
constructor, which mentions the mapOptions property:
http://trac.openlayers.org/browser/trunk/openlayers/lib/OpenLayers/Control/OverviewMap.js#L76
There, documented :)
Tim
Huub Fleuren wrote:
> Hi,
> It appears to be so that the options for the overviewmapcontrol must be
> set like
> var overviewrd = new OpenLayers.Control.OverviewMap({mapOptions:optionsrd});
> Thanks Steven for pointing this out
> Even if I read carefully in de docs i suppose that this is documented.
> Howefer: in the overviewmap.html example it looks like:
> var overview = new OpenLayers.Control.OverviewMap(options);
> Allthough this also works in this case I would suggest that this will be
> corrected in de distribution
> Regards,
> Huub
> Huub Fleuren wrote:
>> Hi,
>> I'm not sure but pretty sure that the overviewcontrol for a projection
>> like 28992 does not work correctly (it does for 4326). What is a good
>> way to go forward with this? Maybe file a trac-ticket?
>> I' referring to my previous contributions in this thread ...
>> I tried using only different options (for the map and the
>> overview)-(holding this carefully the same), it boils down to the units,
>> i guess.
>> var optionsll = {
>> projection: "EPSG:4326"
>> ,maxExtent: new OpenLayers.Bounds( 3.13, 50.45, 7.14,53.32)
>> ,maxResolution: 1500
>> ,scales:[2500000, 1200000, 600000, 300000, 150000, 75000, 37000,
>> 12500, 4250]
>> var optionsrd = {
>> projection: "EPSG:28992"
>> ,units:"m"
>> ,maxExtent: new OpenLayers.Bounds( 0,300000,250000,650000)
>> 12500, 4250]
>> Regards, Huub
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
> !DSPAM:4033,472b21db175308992556831!
