[OpenLayers-Users] drag zoom control images
bradleyspencer
brad at cubewerx.com.au
Fri Nov 2 23:10:40 EDT 2007
Chris,
Thanks for that. I just saved each image again as an interlaced png and it
all works just fine in IE6, IE7 and FF.
If you want the images I can send you, just let me know.
Cheers,
Brad Spencer
General Manager
CubeWerx Australia Pty Ltd
ABN: 37 115 163 285
Mob: +61 (0)404 841 131
Tel/Fax: +61 (0)2 9481 7024
mailto:brad at cubewerx.com.au
http://www.cubewerx.com.au
-----Original Message-----
From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
Sent: Saturday, 3 November 2007 12:46 PM
To: bradleyspencer
Cc: openlayers users
Subject: Re: [OpenLayers-Users] drag zoom control images
On Sat, Nov 03, 2007 at 10:48:02AM +1100, bradleyspencer wrote:
> I?m not sure if anyone else is interested in doing this but I want to
change
> the drag zoom and zoom bar controls to something a little softer in
design.
> I have built some png images and they work fine on IE7 and FF but I am
> having trouble with IE6. They show up as black solid images?
> I have used the pngfix.js solution but it does not help.
The pngfix probably won't work on background images (set via CSS) though
it should work for any images added by default to OpenLayers controls.
However, more importantly, your images don't appear to be transparent,
so I don't think that attacking that end of the problem is the right one
here.
> Does anyone have any suggestion or better images that work?
No, but I really like the images :) Nicely done.
Regards,
Christopher Schmidt
MetaCarta
