[OpenLayers-Users] MediaWikia
Robert J Becraft castlewrks at hughes.net
Sat Nov 3 18:09:48 EDT 2007
Matt Williamson wrote:
> Robert,
> I'm the author of the extension Christopher mentioned (thanks!). Yes,
> check it out, and also the demo wiki at http://s89238293.onlinehome.us/w/
> If you need any help, let me know. The extension also relies on
> another MediaWiki extension called Semantic MediaWiki, which I highly
> recommend anyway. Currently it requires version SMW 0.7, but I've
> officially started work on the modifications necessary to make it work
> with SMW 1.0--I hope to have the update out by the end of November or so.
> Let me know if you have any questions or need any help with it!
> -Matt
Hello Matt,
I got the simple example up and running... I'm now trying to understand
your documentation and convert my map at
http://www.metaphaze.com/Avalon/AMII_world_map.htm to my wiki page.  I
think I blew a gasket trying to follow the documentation.
You have (I believe), two different components mixed together in your
descriptions... part of the setup requires an understanding of the
Semantic_MediaWiki extension and the second part is how your extension
uses that setup to do its part of putting the map together and adding
the elements.
It would be a great help if you could walk me through this process once
so that I can get the gist of it.
Regards,
Robert J Becraft
