[OpenLayers-Users] Sync KML with image map
miles
john.staff2222 at gmail.com
Mon Nov 12 07:46:15 EST 2007
I have a background map in png format and have added it as a layer
according to the examples using the same Bounds coordinates in the
example. I have a KML file with several placemarks in lat/long
coordinates and added it to my OpenLayers as per the example.
How do I get the KML lat/long placemarks correctly located on the
background map? I tried to set the image layer Bounds to the lat/long
limits but then the map didn't even show. Do I need to use a projection ?
function init(){
map = new OpenLayers.Map('map');
var graphic = new OpenLayers.Layer.Image( 'mymap', '/home/mymap.png',
new OpenLayers.Bounds(-180, -88.759, 180, 88.759), new
OpenLayers.Size(600, 300), options);
map.addLayer(new OpenLayers.Layer.GML("KML", "kml/lines.kml", {format:
OpenLayers.Format.KML}));
map.zoomToExtent(new
OpenLayers.Bounds(-112.306698,36.017792,-112.03204,36.18087));
