[OpenLayers-Users] VERY strange behaviour = bug?
Huub Fleuren
huub.fleuren at geodan.nl
Wed Nov 14 11:50:08 EST 2007
Barend,
in Maps.js
* APIProperty: theme
* {String} Relative path to a CSS file from which to load theme styles.
* Specify null in the map options (e.g. {theme: null}) if you
* want to get cascading style declarations - by putting
links to
* stylesheets or style declarations directly in your page.
normally you do not specify this option at all, so the
theme/default/styles.css is always used
but you could add styles with a <link /> anyhow
Regards, Huub
> [version with working links on: http://geoserver.itc.nl/mapserver.OpenLayersBug.html]
> STRANGE BUG?
> when loading Openlayers 2.5 from a location other than the openlayers.org/api site, the OverviewMap's default location suddenly is upperleft iso. lower-right...
> * Load map with openlayers.js script coming from openlayers.org/api hosted site <http://geoserver.itc.nl/mapserver/OpenLayersBugHosted.html> ... => control is in lower-right
> * Load map with openlayers.js script coming from this site <http://geoserver.itc.nl/mapserver/OpenLayersBugLocal.html> ... => control is in upper-left, overlapping the zoom/pan tools
> Even stranger, it worked OK in OpenLayers 2.4 <http://geoserver.itc.nl/mapserver/OpenLayersBugLocal24.html> ...
> I'd consider this a bug, or is it something else...?
