[OpenLayers-Users] Problem in Internet Explorer
    Eric Lemoine
    eric.c2c at gmail.com
    Wed Nov 14 15:37:04 EST 2007
On Nov 13, 2007 5:23 PM, vgvallee <vgvallee at hotmail.com> wrote:
> I'm using Ext.js and got the same problem for a script running in the
> Ext.onReady function call which is supposed to run before the onload event.
> I just put the following line before the definition of that function and I
> didn't get the error anymore.
> document.namespaces;
> Ext.onReady(.....);
We also use Ext here and also has this problem with Ext.onReady on IE
if I recall correctly. Do you understand why adding
document.namespaces fixes the problem? How did you find out?
Eric
