[OpenLayers-Users] Need help understanding UTM
Barend Köbben
kobben at itc.nl
Fri Nov 16 02:45:03 EST 2007
Hi Linda,
> I guess I am just an idiot but I just don't get it. I really appreciate you taking
> the time to try and explain but I just don't get it.
I teach MSc students in GeoInformatics that still don't get it, so don't feel embarrassed. It's just that 'scale' and 'projection' are sometimes hard to get to grips with.
> Yes I want a world map.
> Then when they get down to a certain resolution I want to display UTM.
> What would be really cool is if I could control the box at that level too.
> It needs to be 1200 UTM meters square, 2400 UTM Meters square and
> 4800 Meters square for the zooms.
This is part of your problem. You cannot expect to use data that is useful for a very large scale (4800 msq in UTM on a screen boils down to something like a 1:25000 scale) to also be useable for a small scale world map (on screen something like a 1: 200000000 million scale). That's just plain impossible. Mapping sites like Google Maps use diffferent datasets for different scale ranges, you will have to do that too...
> But if I use a world map it is in either spherical mercator or lat/lon. So
> right now I am hiding and showing a layer. Taking the lat/lon converting
> to UTM when they get to that level and returning that image.
Google Maps and co. do exactly that: Use latlon until a certains cale and then switch to projected meter maps.
> slow and it just isn't working right. It would be easier if the entire map was
> in something like meters that I could go directly to UTM without the lat/lon
> stuff in the middle.
The slowness is likely because of you using the same data set to have both types of maps and doping re-projections all the time. You'll have to use pre-made datasets for the different scale levels for decent performance.
> The UTM image is just not the same image as the lat/lon
> image. Even though the coordinates are directly converted. I am so frustrated.
Of course they are not the same. Projection of a spherical object (Earth) to a flat cartesian object (projected map) always will introduce distortions. Imagine peeling an orange and flattening the skin. It will distort (and probably break).
> I need a road map.
So make yourself one :-) But don't try to do it from a world dataset. Or maybe better: use an existing road map, where people have done the hard stuff for you already. Can you use Google Maps as a background layer in your OpenLayers stack? If you need the actual road DATA, you could consider the free OpenStreetMap (openstreetmap.org <http://www.osm.org/> ), although their coverage is not so good for some parts of the world. Otherwise you might have to buy some data from teh likes of NavTech or TeleAtlas...
Barend Köbben
International Institute for Geo-information Sciences and Earth Observation (ITC)
PO Box 6, 7500AA Enschede (The Netherlands)
ph: +31-(0)534874253; mobile: +31-(0)622344955
