[OpenLayers-Users] searching a feature with open layers
Arnd Wippermann
arnd.wippermann at web.de
Fri Nov 16 18:29:29 EST 2007
You can apply a filter to the WFS layer.
WFSlayer.mergeNewParams({'filter' : yourFilter });
But this works only, if the filtered feature is visible in the current
extent of the map. If you know the centerpoint of the features, you can set
a new center for the map after applying the filter.
Example:http://gis.ibbeck.de/ginfo/apps/OLExamples/SphericalMercator/wfs_fil
ter.html
Mit freundlichen Grüssen
Arnd Wippermann
-----Ursprüngliche Nachricht-----
Von: bjoice at firstam.com [mailto:bjoice at firstam.com]
Gesendet: Freitag, 16. November 2007 08:55
An: arnd.wippermann at web.de
Betreff: RE: [OpenLayers-Users] searching a feature with open layers
Thanks,
I would like to know , can I pass the value of an attribute (eg : In
top:states , can pass STATE_name ="texas') instead of maxfeatures with
OpenLayers.Layer.WFS.
Thanks, .
-----Original Message-----
From: arnd.wippermann at web.de [mailto:arnd.wippermann at web.de]
Sent: Thursday, November 15, 2007 10:40 PM
To: Joice, Binny
Cc: users at openlayers.org
Subject: AW: [OpenLayers-Users] searching a feature with open layers
You can load your WFS with OpenLayers with option 'extractAttributes': true.
//OpenLayers.ProxyHost for WFS needed!!!
layerWFS = new OpenLayers.Layer.WFS( "WFS Titel", WFS_Url,
{typename: "POLYGONS", maxfeatures: 500}, { typename: "POLYGONS",
extractAttributes: true});
Now you have access to the features geometry and the features attributes.
Arnd Wippermann
http://gis.ibbeck.de/ginfo/apps/OLExamples/SphericalMercator/OL_900913_frame
s.html
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von goeserver developer
Gesendet: Donnerstag, 15. November 2007 07:31
An: users at openlayers.org
Betreff: Re: [OpenLayers-Users] searching a feature with open layers
Thanks,
Suppose I have a layer like states , I need to spatially locate , a
particular feature (like : name =texas)it on the map . With javascipt and
WFS I am able to do it . But with openlayers ,how could it be done.
Eric Lemoine-3 wrote:
> On Nov 13, 2007 1:19 PM, goeserver developer <bjoice at firstam.com> wrote:
>> Hi,
>> How can I include a search ? I am displaying the topp:states layer
>> along with google map with openlayers. I also want to include a
>> textbox where I can key in the state name to search. How will
>> geoserver
do the WFS part?
>> Can it be done with Geojson.
> I'm not sure I fully understand your need, but you may be interested
> in this example:
> <http://www.openlayers.org/dev/examples/getfeatureinfo.html>. WMS
> GetFeatureInfo is used on each click in this example.
> Eric
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context:
http://www.nabble.com/searching-a-feature-with-open-layers-tf4797435.html#a1
3761443
Users mailing list
This message contains confidential information intended only for the use of
the addressee(s) named above and may contain information that is legally
privileged. If you are not the addressee, or the person responsible for
delivering it to the addressee, you are hereby notified that reading,
disseminating, distributing or copying this message is strictly prohibited.
If you have received this message by mistake, please immediately notify us
by replying to the message and delete the original message immediately
thereafter.
Thank you.
FADLD Tag
