[OpenLayers-Users] How do I unselect a feature?
mike
mike at bristolbeat.co.uk
Sat Nov 17 08:20:53 EST 2007
I get the same behaviour - in the select-feature demo, clicking on the
selected point unselects it, but in modify-feature it does not.
I also wonder if in both cases, clicking away from the object on an empty
part of the map should unselect the selected feature.
Otherwise, this example is really very good - thanks!
mike
Message: 2
> Date: Fri, 16 Nov 2007 12:18:17 -0600
> From: "Jeff Dege" <jdege at korterra.com>
> Subject: Re: [OpenLayers-Users] How do I unselect a feature?
> To: <users at openlayers.org>
> You're absolutely right - in the select-feature demo, clicking on the
> selected point unselects it.
> But in the modify-feature demo, clicking on the selected point does not.
> http://openlayers.org/dev/examples/modify-feature.html
> The problem seems to be in Control.ModifyFeature, not in
> Control.SelectFeature.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20071117/03e494ff/attachment.html
