[OpenLayers-Users] status of OpenLayers.Layer.TileCache ?
Paul Spencer
pagameba at gmail.com
Wed Nov 21 06:58:08 EST 2007
On 20-Nov-07, at 10:10 PM, Gregor Mosheh wrote:
> Paul Spencer wrote:
>> TileCache is working for me. Note that TileCache layers point to
>> the root directory of the actual disc cache of your tiles, not to
>> the TileCache cgi.
> Yup, got that. I was having some odd problems with the other layers
> (GeoRSS layers) vanishing and never returning. Are you using 2.5 or
> a SVN/CVS version? Cuz if "it works for you" in the 2.5 release,
> then I'll put more effort into debugging it.
> I'm looking forward to seeing Layer.TileCache in action. The "plain
> old file" requests will be very amenable to Apache's mod_mem_cache
> and I suspect that the performance in such conditions could be
> breathtaking
Gregor, I'm just using the TileCache layer by itself, not with other
layers. I'd be a bit surprised if it was interfering with other layer
types, but then again stranger things have happened. Do the same
things happen if you swap out TileCache for TMS pointing at the same
service, or is it just the TileCache layer that causes the problem?
Oh and yes, its 2.5 final that I am using.
Cheers
Paul
