[OpenLayers-Users] Selecting a feature - does not always work
Nick Whitelegg
nick at hogweed.org
Wed Nov 21 19:01:59 EST 2007
Hello everyone,
Another problem relating to the 'osmajax' editor
(http://www.free-map.org.uk/freemap/javascript/osmajax-0.5/index.php - see my
last post). Selecting a feature does not always work - the feature always
goes blue but sometimes the status message at the top does not read "you
selected a feature with ID xxxx". Tests in my code reveal that the variable
"selectedFeature" is not always set. My code to respond to a mouse click on a
feature:
this.selectUp = function (f)
if(f instanceof OpenLayers.Feature.OSM)
var item = f.osmitem;
var msg;
if(item.type != 'unknown')
msg = 'You selected a ' + item.type;
else
msg = 'You selected an item of unknown type ';
if(item.tags['name'])
msg += ' ('+item.tags['name']+')';
msg += ' with an ID of ' + item.osmid;
self.statusMsg(msg);
self.selectedFeature = f;
Any ideas what might be wrong here? Using openlayers 2.4.
The behaviour appears to occur randomly.
Thanks,
Nick
