[OpenLayers-Users] Drawing on the fly route
Roald de Wit
rdewit at users.sourceforge.net
Wed Nov 21 22:40:54 EST 2007
On Wed, 2007-11-21 at 11:47 +0100, Matthew Pulis wrote:
> Hi guys :)
<snip>
> I get this error :
> String contains an invalid character" code: "5
> http://yancho.no-ip.org/~yancho/OpenLayers.js
> Line 554
Not sure: could it be your XML is in another character set (in
ISO-8859-1 for example) than it says it is (UTF-8)?
I see you use a single quote for your edge id. What happens when you
make that a double quote?
Or maybe you tried to do something like this:
http://www.nabble.com/DrawFeature:-box-supported--t4627077.html
If so, you tried to feed the data in a wrong format to a method, or
maybe the right format to the wrong method... ;-)
Kind regards,
Roald
Roald de Wit
Software Engineer
roald.dewit at lisasoft.com
Commercial Support for Open Source GIS Software
http://lisasoft.com/LISAsoft/SupportedProducts/
