[OpenLayers-Users] [Tilecache] out of range bbox requests and Tilecache failures
Christopher Schmidt crschmidt at metacarta.com
Thu Nov 22 07:32:18 EST 2007
On Thu, Nov 22, 2007 at 10:00:19AM +0000, David Herbert wrote:
> Apologies for cross-posting this - not sure quite where it belongs.
> While using Firebug (Firefox 2.0.0.9 WinXP) to look at performance and
> client-side memory usage of my OpenLayers 2.5 app (which uses Tilecache
> 1.9 in standalone server mode with a seeded cache of WMS layer images),
> I noticed a large number (50+) failed 404 responses for images e.g:
> http://10.48.1.76:8084/?LAYERS=Coastline%20and%20bathymetry&STYLES=sggis_bathymetry_polygon%2Csggis_coastline&FORMAT=image%2Fpng&TRANSPARENT=off&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A2007056&BBOX=-82000,-43494.81471999999,-30705.185279999998,7800.000000000015&WIDTH=256&HEIGHT=256
> Now the BBOX values being asked for in this request are way outside the
> bounds I have specified in tilecache.cfg - here is the extract for the
> above layer:
> [Coastline and bathymetry]
> type=WMSLayer
> url=http://10.48.1.76:8080/geoserver/wms?transparent=off
> layers=sggis:bathy_poly,sggis:coastline2007
> extension=png
> #extent_type=loose
> bbox=-82000,7800,80000,116000
> maxResolution=200.370370
> srs=EPSG:2007056
> metaTile=true
> (The coordinates are a metre projection for South Georgia in the
> Southern Ocean). Tilecache correctly reports this with the following
> error:
> An error occurred: Lower left corner (-82000.000000, -43494.814720) is
> outside layer bounds [-82000.0, 7800.0, 80000.0, 116000.0].
> To remove this condition, set extent_type=loose in your configuration.
What is the maxextent of your OpenLayers Map? OpenLayers shouldn't
request tiles outside your maxExtent: If it is, I would suggest rounding
off your maxResolution (in TC and OpenLayers) -- floating point errors
can cause OL to request tiles it shouldn't.
(I'm hoping you're not using 'displayOutsideMaxExtent'.)
I think you've hit a couple things: the bug in TileCache, below, and
what sounds to me like a configuration change needed in your OpenLayers
setup. I'd recommend we omit the latter for now -- it's annoying, but
*shouldn't* be affecting you -- and concentrate on how to fix your OL
configuration issue -- which means followups should go to OL-Users.
> An HTTP 404 response is generated.  If I do as the error suggests and
> set extent_type=loose (uncomment the line above) then I notice a marked
> drop in performance - one layer takes half a minute to load from the
> cache for some reason.  There are also 20-30 HTTP 500 responses which
> generate the error:
Right. This is a bug in Tilecache that I haven't fixed: metaTiling
results in requests outside the bounding box failing, so each tile is
requested, others wait to get the lock, then they're requested, etc. in
sequential order.
Regards,
Christopher Schmidt
MetaCarta
