[OpenLayers-Users] WFS Problems
Eric Lemoine
eric.c2c at gmail.com
Thu Nov 22 08:52:00 EST 2007
On Nov 21, 2007 8:53 AM, goeserver developer <bjoice at firstam.com> wrote:
> Hi,
> Could you get a solution for it. I too have the same problem.
> Any help will be appreciated .
Hi
If you use FireFox and Firebug check the content of the response to
the WFS GetFeature (Ajax) request. More specifically check if you
actually have features in the GML response. If not, maybe there's no
features in your current map extent. If your GML does include
features, please post your GML file here so we can investigate the
problem further.
Thx,
Eric
> ihaddad wrote:
> > hi guys,
> > i know i've posted something similar, but i am still having some problems.
> > i created a table in postgis with (id, name,the_geom) where the_geom is a
> > geometry column of type Point. then i created a featuretype on geoserver
> > with that table.
> > now i am trying to show these features on my map using this...
> > <!-- part of the code -->
> > landmarks = new OpenLayers.Layer.WFS( "Landmarks",
> > "http://192.168.0.4:7070/geoserver/wfs",
> > {typename: "topp:landmarkpoints", maxfeatures: 10},
> > { featureClass: OpenLayers.Feature.WFS});
> > map.addLayer(landmarks);
> > <!--end of the code -->
> > yet nothing is displayed!!
> > i want those features to be displayed as points on my map, i am using wfs
> > becuase later i want to make a conditional query on that featuretype to
> > get only part of the features( landmarks) and display them. i am not sure
> > if i can do that in wms!
> > one more thing...does openlayers support wfs-t? i saw a very beautifull
> > example that comes with geoserver (mapbuilder) that uses wfs-t to add
> > points and lines to the map.
> > will that be possible one day on openlayers???
> > thank you.
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> View this message in context: http://www.nabble.com/WFS-Problems-tf2762836.html#a13872485
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
