[OpenLayers-Users] out of range bbox requests and Tilecache
failures
David Herbert
darb1 at bas.ac.uk
Thu Nov 22 10:29:01 EST 2007
Christopher,
Further to my last post - setting maxResolution to integer 200 rather
than the slightly larger float value does indeed appear to fix the
problem. That is, I no longer get any out of range requests - looks
like you were right that there was a rounding error somewhere.
Thanks again,
David.
This message (and any attachments) is for the recipient only. NERC is subject
to the Freedom of Information Act 2000 and the contents of this email and any
reply you make may be disclosed by NERC unless it is exempt from release under
the Act. Any material supplied to NERC may be stored in an electronic
records management system.
